Jims RV-8
Date:  1-8-2014
Manual Reference:  7-11
Brief Description:  Rivet spanwise row on Right leading edge
The next step was to use the squeezer and rivet the triling edge, top and bottom of the leading edge to the spar. Most of the rivets are 426 (flush) AD 3-4's, except for the the ones that also go thru the ribs, those are 3-4.5's so they are a little longer. I had to do a little de-construction on the wing stand to get to the bottom side of the leading edge - but it went well.
top side - looking smooth
bottom side
bottom side
wing stand structure is in the way...
