Brief Description: Countersink left spar bottom & primed
Tonight I flipped the wings around and countersunk the bottom of the left spar, manually countersunk the phantom holes, then primed all countersunk holes. I also moved the tanks inside to prepare them for the leak test - cold weather is on the way and being inside will lower the temperature differential.
