Jims RV-8
Date:  10-13-2013
Number of Hours:  1.50
Manual Reference:  7-7
Brief Description:  Right tank sender unit float work
I bent the right tank sender unit. It would be nice to have been able to use the left tank float wire as a guide, but since this is going in the inverted tank (right tank) it is attached to the baffle of bay #2, instead if the inside rib of bay #1…so the geometry of the tank is different. In the end, I had to make 4 “coat hanger prototypes” to get the lengths and the angles just right before I was satisfied. But all in all it worked out great.
I did end up bending the first 90 degree the wrong way, so the “Shepherd’s crook” is on the top side when the tank is full/float is “up” instead of the bottom side…oopps. I debated whether to go buy another 3/32” rod and make another one, but I noticed that the shepherd’s crook had a lot of distance that wasn’t contacting/holding the float, and knew I could just file that part off and be ok. I did make sure that the crook did not contact the top of the tank skin before and after filing down the crook, and to make extra sure, I pro-sealed the end of the crook so if it ever does contact the skin, the proseal will touch and it won’t be metal to metal contact.
ready for install
ready for install
