Brief Description: ProSeal the right tank anti-rotate brackets
I did this yesterday, but It's a pain to get things in the correct sequence with this logging software - so here you go.
After finishing the riveting yesterday, I cracked open the tank sealant and mixed a batch. I torqued the fixed fuel fitting and bucked the two rivets into the anti-rotate/access plate and the anti-rotate for the flop tube.
* I did the usual ProSeal drill - Cleaned all the parts in MEK - torqued the fuel pickup fitting - riveted the parts, then covered in pro-seal. But now we are all riveted - and all covered in ProSeal...at least these parts are. I still need to bend the wire for the floats that go into the fuel sender units in each tank to send the fuel level... I hope to get that done on the 24th.
