Tonight Bob and I put on all 4 top skins and got them drilled. It really helps having an extra person to move the clecos behind me after I got thru drilling. The way it worked, we put a cleco in every second hole and then after I had drilled the holes without clecos and marked them, Bob would come in behind me and move the clecos one hole, then I would come back thru and drill the new holes. It's much more efficient doing it that way!
After we drilled the top skins, we put the bottom skins on and got all of the left wing clecoed and some of the left wing.
Not much different picture - but you can see that the bottom and top skins are on.
