Jims RV-8
Date:  5-11-2013
Number of Hours:  0.00
Manual Reference:  7-2
Brief Description:  (cont.) Tie down-assembly - left spar
The method for drilling the tie-down assembly is to dirll the match hole to the specified dimensions on the tie-down assembly, then bolt the tied-down assembly to the spar and back drill the remaining needed holes. It worked out pretty good... I got the left tie-down completely drilled and the two spacers main holes are drilled. Hopefully tomorrow I can get the right spar tie-down done.
level the spar...
level the spar...
make sure tie down is perpendicular
...finished back drilling the tie dow/spacers
