Brief Description: Getting closer - more glass work
More of the same - sand the parts down smooth and look for pin holes and valleys that need to be filled in. Yep I got 'em and so I mixed up some more slurry and applied it to the left elevator top, right elevator top, rudder tip, rudder bottom, and VS tip. After it dries I will sand, filler primer and repeat. The right HS tip is done - nice and smooth - at least on the top.
