Jims RV-8
Date:  8-4-2018
Number of Hours:  1.50
Manual Reference:  6-14
Brief Description:  Empennage fiberglass work + sanding
I looked at my previous fillet that was 2x glass layup and I think I didn't put enough mix into the glass as it looks like it has air pockets in it. I can do better. So I mixed up some more resin and cut 4 pieces of glass this time and really wetted each layer well. After using the clean resin, I added micro bubbles to continue the HS/Elevator tips fairings. I spread it with a squegee and left it to dry. While I had the mix I used it on the hole in the right skirt to do the final fill.
4x fillet work
4x fillet work
micro bubble mix on right side
canopy skirt work
canopy skirt work
