Brief Description: Rod Ends inserted (147.25 hours)
Tonight I made a tool from the pvc to be able to insert/tighten the rod ends. Then I was able to install the rod ends. I first measured the distance specified by the plans and dialed in a close approximation and set the rod ends in. I will do the final adjustments later when I install the rudder on the VS.
Total hours = 147.25
avg / month = 49.08 hours
cool tool - hard to see but there is a notch in the end
