Basically tonight I started putting the right elevator substructure together and put the counterweight ribs and counterweight together...and drilled the counterweight attach holes. Nothing too exciting - but a little bit nerve-wracking to go thru this...but sometimes you just go for it. I started off by drilling the holes to a #40 and then went up to the #12.
started off with the #40 and the electric drill
...then went to the drill press with the #12
...all drilled and clecoed together - holes to be dimpled/countersunk
