Finished up with the right side…now I have to do all the same steps for the left side….the good news is, this side should go faster The bad news is that the right rib, HS-706, bent in at the tip. The last hole in that rib tip is not prepunched so it has to be drilled – at some point the rib bent slightly at the end and as a result, the edge distance was too close – so I ordered another one to be on the conservative side.
