I picked up some 1 ¼” screws to replace the 1” screws that are currently holding the 5 fuse busses. The 1” screws were a little short as there were no threads protruding past the nut. Although there is not much tension on those screws, I didn’t want to take a shortcut here and be reminded of it every time I open the baggage door. I also picked up a 12 port fuse block that Greg had leftover so I switched out my 8 port for the 12 port and now I have more capacity. I had not drilled the two upper holes on that buss as I was contemplating the upgrade – so it was perfect timing that Greg asked if I needed the 12. Thanks again, Greg! I drilled the two holes additional holes in the Battery Buss (the new 12 port) and installed the new screws. I continued taking out the short screws and installing the longer ones all were done. There... I am kinda surprised it took this long.
