Brief Description: Smoke system pump and front seat heat
The smoke system pump is being made to be removable along with the smoke oil tank so there will be a quick disconnect on the pump wires. The pos/neg pump wires will then go to a switch in the right console panel which will engage/energize the circuit and allow the button on the pilot control stick to turn on/off the smoke pump. I am wiring the quick disconnect and will then work on the wiring to the aircraft power / ground.
While I am at it, I decided to finish wiring the power/ground for the pilot seat heat. So I pulled the spools of the wall hanger and fished them up thru the right side console area and up near the ships power / ground. I cut and stripped the wires, inserted the shrink wrap and terminated the wire. Heating the shrink wrap after inserting the label was the last step.
