Jims RV-8
Date:  11-19-2019
Number of Hours:  1.00
Brief Description:  Molex on the rear seat heat connections
Installed both the molex pins and terminal connections after they arrived in the mail today. Also inserted the labels into the heat shrink and heat-shrunk them on :) Not as easy working on wire that is already in the airplane and run thru its channels. Rear seat heat wiring is now done. The seat heat panels will be installed into the seat pads when I order the seat pads and seat covers.
Also labeled and terminated the rear USB power - it is now done too.
USB terminals on the left, Seat heat on the right
molex on the power supply
