Jims RV-8
Date:  11-13-2019
Number of Hours:  3.00
Brief Description:  Rear seat hinge and GIB ergonomics
Unfortunately, It took me 3 tries on the rear seat hinge... The first replacement hinge was made with the wrong material and the hinge pin size was too small...so I drilled all those rivets out and did it again using the correct material. I did use the correct material but in this round, I riveted the hinge too close to the seat material and it was binding a little... well, third times a charm! And it was.
After getting the rear seatback corrected, I asked Teresa to come out and "try on" the rear seat ergonomics. We discussed the seat heat/USB location and talked about maintenance and using the appliances and getting in and getting out, sitting with, etc. In the end, we decided that it would be worth the maintenance bonus to not have the switches located in the arm rest, but rather, under the arm rest, on the side panel.
front seat
front seat
rear seat
rear seat
Teresa trying on - but no makeup, so covering up :)
