Jims RV-8
Date:  8-28-2017
Number of Hours:  1.00
Manual Reference:  9-2
Brief Description:  Prep for canopy cutting
With all the overcast weather we have been having related to Hurricane Harvey, the shop is actually pretty cool for a change. Unfortunately, the canopy likes warmer temperatures when it's time for cutting. My friends in south Texas could sure use some more heat and sunshine!
I got a late start on the work session tonight and didn't feel like I had enough time to do some cuts and get the cuts sanded. Instead, I got the sanding blocks put together, got the die grinder set up and lowered the rotisserie to lowest level so as to allow easier access to the canopy area.
84 degrees
84 degrees
lowered the fuse
lowered the fuse
set up the sanders and the
