Tonight I re-routed the green wiring from the power bus to the engage switch and ran it from the engage switch to the relay instead. I also ran the second lead from the engage switch to the stick switch area to connect later with the rest of the stick connections. This is what will connect to ground and close the relay when both the engage switch and the stick switch are activated. I ran the new, thicker power wire from the power source to the relay, started running the pump ground wire, and completed all connections and labels.
