Jims RV-8
Date:  8-5-2022
Number of Hours:  1.00
Brief Description:  Build a landing gear primer stand
Using the old fuselage stand I had been storing outside and some scrap lumber, I cobbled up a stand to hold the landing gear in suspension for priming. The idea is to suspend the landing gear from the upper cross member with wire, which should allow me good access to spray the entire landing gear. I would have liked to make it taller, but this was as tall as I could make it with the available lumber on hand.
