I went to install the baggage floor and was getting an interference with the new cable run so using fingers, lights and mirrors I located the problem area and then went about the process of removing the interference. The metal shears and the Dremel made quick work of it and then I sanded the cuts smooth and put some primer via Q-tip, on the fresh metal. Re-installed the baggage floor and found the fit like new.
