Jims RV-8
Date:  6-8-2020
Number of Hours:  0.40
Brief Description:  Remove LG bolts that were too short
Since the 2 installed bolts were going to be a little too short and I had received the new, longer bolts, it was time to remove the old bolts and prep the fuselage for the rotation...again.
If you are using a one-piece Grove gear on your RV-8, make sure to use the NAS6606-36 bolts.
I have some NAS6206-36 if you need them...
Correct bolts
Correct bolts
