Jims RV-8
Date:  5-12-2020
Number of Hours:  1.00
Brief Description:  Prep and prime landing gear bolt retainers
I preped the gear bolt retainers by buffing and deburring them and then shot a coat of primer. I will have a discussion with Bob about the best way to get those gear bolt retainers installed on to the bolt, into the gear tower and in the hole. It will be a chore as these are close tolerance bolts that will take some doing... but the payoff is after I get them installed, the torque procedure gets much easier for--ever.
after deburring, before primer
after primer
after primer
