Jims RV-8
Date:  1-20-2020
Number of Hours:  1.50
Brief Description:  Finished wiring the front cockpit lights
I ran the two positive wires on the LED lights and then hooked everything up to the switch, the power and the controller. At first, I had flipped the wires on the switch and it was not functioning as intended - but after looking at the orientation of the switch and the 6 posts, I fixed the wiring and all was good. Now it's OFF - RED - WHITE and the dimmer works.
Not anything really to take a picture of but took two anyways. There is starting to be a lot of wires already and I am just getting started…
One light switch and one controller working
I will tuck the wires under when finished
