Jims RV-8
Date:  12-4-2019
Number of Hours:  1.60
Brief Description:  Front seat heat
Borrowing from my buddy Rob's front seat switch location, I decided to put my front seat heat switch in the same location that he did. Thanks, Rob!
I first planned out where all the guts would go under the front seat ramp and how the heating pad wires would run as well as where the positive and negative wires would run to power and ground. I wired the molex terminals on the "gut" side wiring and drilled the ramp support and notched the hole for the switch notches and the switch fit is good. I still need to wire the power and ground side and drill the seat ramp for the relay mount bolt.
test fit of the
test fit of the "guts" under the front seat ramp
front seat heat switch installed
plenty of room to activate the switch
