Jims RV-8
Date:  8-18-2019
Number of Hours:  2.50
Manual Reference:  9-5
Brief Description:  Storage - latch and primer
I measured and drilled the corner holes for the canopy latch and then using the dremel cutting wheel, I cut along the lines between the holes - then files and smoothed the edges.
I installed the latch but there was a bit of a gap between the top of the latch and the bottom of the door - so I cut out a scrap piece of metal and drilled, dimpled, deburred and riveted it. I also added a stiffener to the door and then cleaned the storage assembly and then primered it. Now all it needs is paint and it will be done...but I will need to wait for more favorable temps.
Four holes and measurements
latch installed
latch installed
primed and ready for paint
