Jims RV-8
Date:  3-23-2019
Number of Hours:  1.50
Manual Reference:  9-3
Brief Description:  Smooth the aft canopy skirt
With the aft hole closed up in the aft end of the canopy skirt, it's time to smooth the glass. I sanded down the known high spots until it felt pretty good by hand. Then I sprayed a coat of primer on it which makes it easier to see the imperfections, then more sanding, then another primer coat, then the last sanding.
I mixed up some resin and bubbles and spread the thick mix on the skirt with the card method to fill in the low spots and pin holes.
after first sanding
after first sanding
after third sanding
after third sanding
divits, pin holes and low spots filled in
