Brief Description: Final sanding and primer removal
I did a final sanding on the fiberglass tips on the elevators and the top and bottom of the rudder. After the final sanding, I took some acetone and removed the sanding primer completely. I am not going to look at the tips anymore and whatever needs fixing will get fixed at the paint shop. Now I need to do the same for the horizontal stab tips and the vertical stab tip.
