Jims RV-8
Date:  9-23-2018
Manual Reference:  6-14
Brief Description:  Dis-assemble the empennage
Getting the bottom sides of the tips smoothed out with the fiberglass slurry mix will require me to dis-assemble the empennage to make it easier to get to the bottom sides tips. The rudder was already removed so I removed the vertical stab - then the elevators, then the horizontal stab.
I also read a thread on the VAF about not having the lower nuts/washers/bolts in the fuselage when the VS is not installed can sometimes cause the aft bulkhead to suffer stress. This is due to the aft bulkhead being supported by just a few small rivets (if the bolts/nuts/washers are not installed). To make the longer bolts fit, I installed some wood spacers. I don't see any problems with not having the bolts installed previously, but don't want to beg for trouble.
empennage off again
empennage off again
VS tip ready for final fillet and
re-installed the bolts to support aft bulkhead
