Brief Description: Canopy Skirt #17, removed spacer for test fit.
I wanted to make sure what the final fit was going to look like after the spacer was removed and the canopy frame was able to slide all the way to the stop (Slide block hitting the anchor block) – with the canopy/skirt in the forward most position. I wanted to see this as I wanted to see how that changes the fit of the canopy skirt at the aft end…well, I didn’t like what I saw at first, but I think it will actually be better in the long run…
