Jims RV-8
Date:  8-5-2018
Number of Hours:  1.30
Manual Reference:  6-14
Brief Description:  sanding and more VS fillet work
I attached the VS fillet into the VS with resin and let that start setting up. I sanded down the right side HS/Elevator and am fairly close on that side. So I went to the left side and put on my first layer of slurry over there. To make sure that the VS would still fit right I put a little slurry on the outside bottom and installed it back on the VS to let it final cure. I learned my lesson.
