Brief Description: Empennage fiberglass work + sanding
I looked at my previous fillet that was 2x glass layup and I think I didn't put enough mix into the glass as it looks like it has air pockets in it. I can do better. So I mixed up some more resin and cut 4 pieces of glass this time and really wetted each layer well. After using the clean resin, I added micro bubbles to continue the HS/Elevator tips fairings. I spread it with a squegee and left it to dry. While I had the mix I used it on the hole in the right skirt to do the final fill.
