I wanted to do the final cleanup of the sika adhesive of the canopy so that I could go ahead and do a cosmetic coat and get my final black sika lines known. I worked off the excess glue that was over the tape line and not adherring to anything - call it "overspray" - over really over-spread would be more appropriate. Also cleaned up some spots on the underside and cut out some over done sections with a box cutter. I almost think I could get by with the way it looks but there are a few spots that are not smooth that the passenger would likely see - nothing that is a structural problem, just not smooth - so I will want to cover that up with a cosmetic coat. However, I still need to figure out how to make the cosmetic coat better than the first coat. I wish the sika was a little more "Fluid" so it would just smooth itself out.
