Jims RV-8
Date:  9-28-2017
Manual Reference:  9-3
Brief Description:  Canopy cutting and sanding #14
I went a different route with marking the next cut line. Since it is getting close to the right fit, I decided to use the painters tape and tape off the upper limit and then I covered everything below the line in red sharpie. Then I peeled off the tape and had a nice cut line which I will use to cut in the upper range of the red sharpie. It seemed to be quicker to lay down the tape and then marking was much easier than using the ruler. It's a learning process.
I then cut the perimeter and sanded it down. I was going to place it back on the frame and take a look but the Horns are playing tonight so that all for now.
left side with tape and marks, right side already peeled
this is how I set up for cutting, canopy overhanging the bench
