Brief Description: installed controls, sticks and pushrods
I installed the pushrod assembly, the pushrods, control sticks and installed the nut/washer/bolt combinations and torqued them down (except for the rod end bearing on the F-837-1 aft control mount, which is marked in green tape). The un-torqued rod end bearing will be coming out to install the floors so I didn't torque that one yet. The hardest part of doing all that tonight was getting the small interior washers installed!! There were also some access issues but patience and outside the box thinking prevailed. I used the new red torque paint on the torqued nuts too.
front control stick will still need to be cut down
