Jims RV-8
Date:  11-8-2016
Number of Hours:  1.40
Manual Reference:  8-58
Brief Description:  Masking and rotisserie (engine stand)
I needed a little distraction so I wouldn't be tied to the election results ALL night, so I went to the shop and started masking the fuselage parts that I don't want to be gray. I will put some paper on the sides of the fuse, but got the line tape down and the rollover bar covered and then moved on to the inner parts of the fuse. I quickly realized that it's a bit of a stretch to lean over and reach in to do the inside - well, it will be a lot easier with the fuse on the rotisserie - so I might as well start building that.
I have had the engine stand for almost 2 years but have been reluctant to drill the engine mount holes - but here we are. So, I built the stand and rolled it into it's temporary spot - then remembered I needed a picture of it. Click.
