Jims RV-8
Date:  6-23-2016
Number of Hours:  1.00
Manual Reference:  8-52
Brief Description:  tap cable anchor
I started to tap the 4 holes in the cable anchor and broke the tap in the second hole. It was off to the Ace hardware for another 8-32 tap. Four bucks lighter and I was back in the tapping business. Luckily there was enough meat on the bone to clamp on to the broken piece of the tap with some vice clamps to remove the broken piece of the old tap. I also noticed that the outer hole looked a little higher/closer to the top than the next one. I made another 3 holes in another attempt but then realized I made it with the bend on the wrong side. Oh well, I email Van's support and asked them if the one hole being 1/32" off would be a problem but Gus said, "no" there is movement up and down in the cable throw anyway.
