Brief Description: Prep work for bottom front skin priming
I pulled off the aft bottom skin F-850 and made the last of the cuts and smoothed those cuts...I am happy with the fit of the bottom skin parts - relative to the landing gear brackets. Then I climbed underneath and fed the fuel vents up thru the holes in the floor skin and screwed in the bottom portion of the vents.to see what they looked like. I put the F-851 skins together with the cooling ramp and looked at how it all went together - I am pondering if I will put some stiffeners under the ramp so I was looking at that. In any case, the front bottom skins are ready to be scotchbrited and primed and with a spot of good weather coming our way in two days - the plan is to do some priming Sunday.
