Brief Description: lower front skin cutting and smoothing to LG
I installed the F-851 lower front skins as well as the landing gear (bolts only) and the cooling ramp. I didn't get to install the parts right away, I kept marking the parts where the landing gear brackets were interfering and then I cut away as little metal as possible, reinstalled and then marked and cut some more. Multiple iterations of marking, cutting, then re- installing to see if the holes were lined up and the clecos would go in. I still have some more smoothing to do but well on my way.
