Brief Description: Finished rivets on the Front spar, some rib rivets
Scott was back in the shop tonight and we got the spar/doubler/angle rivets finished up on the front spar. Then it was on to the HS-00005 and HS-00006 ribs. Those were more difficult as the angle of the ribs doesn't leave much room. The other issue is I didn't get the hole drilled exactly in the center of one of the HS-00006 ribs. So I may have to work on those rivets a bit.
