Jims RV-8
Date:  6-25-2015
Number of Hours:  1.50
Manual Reference:  8-35
Brief Description:  Prep for riveting F-820-L/R-1 fwd side skins
Before installing F-820-L-1 & -R-1 Fwd Side Skins in this step I need to apply a 1/8" bead of tank sealant or fire barrier. I choose the 3M Fire Barrier 2000+ Silicon Seal for this job and applied a bead to the "corner" of the firewall flange (see pic #1). I then clecoed on the the left side skin and repeated the process on the right side. On pic #2 you can see the "After" view of the right skin clecoed and the fire barrier seal in between the firewall and side skin
fire barrier seal applied to left firewall flange
right forward side skin
fire barrier 2000+ Silicon Seal
