I bent up the side cover tabs and then test fit the ramp for the umpteenth time. I clamped/clecoed the side cover to the ramp and then drilled 3/32" holes for rivets. I will dimple them later and then prime both parts. I also lined up the bottoms of the gauges in the ramp and marked the bottom 4 holes and then drilled them. I marked the top 4 and drilled those also.
