Brief Description: Preparing Fuse Parts for Final Assembly - 2
Today was Jerry Jeff Walker day in the shop - time to get some work done with some Texas music in the background... Here is what I did today :
* Countersunk the F-844 Auxiliary Longeron side webs * Countersunk the F-817 Seat Back Support Plates * Countersunk the F-804H-1 Center Section Side Plates * Countersunk the F-856-1 Spacers * Countersunk the F-843 Lower Longeron side webs * Countersunk the F-844 Auxiliary Longerons and at the Fuel Valve angle mod * Countersunk the F-802D L. G. box plates * Countersunk the F-857C Angles * Countersunk the F-814C-1 Inboard Seat Rib Angles * Countersunk the F-888 Aft Mid Longerons * Countersunk the F-889 Aft Lower Longerons * Countersunk the F-887 Upper Longerons
Then I deburred one of the F-887 Upper Longeron ... and the shop was such a mess, I had to do a little cleanup and sweep up all of those countersunk shavings! That's all for now.
