Ivans RV 10
RV10
Wiring
8-30-2008
OP 37-3 to 4
circuit breakers and terminal block
OP 37-3
Step 3 and 4 Drilled holes for CB/ SCB using 801RT console Template as a guide.
Step 5 Installed SCB/CB as shown.
Planning on mounting flap switch in grip . Haven't mounted Flap Control Board Yet.
OP 37-4
Step 1 Made the Terminal block from the supplied UHMW material. Then assembled with the hardware called for.
Step 2 Attached Term Block to Sub Panel and drilled holes for Ground conn. on either side of term. block.
Step 3 Made the P21 and 22 Buss bars from supplied copper plate.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
