Ivans RV 10
RV10
Baggage Door
7-19-2008
Baggage door assembly
34-2
Step 1: bent the F 1059B Upper frame to the proper set.
Step 2: Clecoed the frame to the F 1059E Skin.
Steps 3 & 4: Repeated process for lower frame as well.
Step 5: Clecoed the F 1059A frame to the tabs on the other frames and to skin.
Step 6: Clecoed lock bracket to frame and skin.
Step 7: Clecoed the Closeout panel to the F1059A,B and C frames
34-3
Step 1: Centered door in opening and marked the upper and lower hinge recess points.
Step 2: Made hinge from AN257-P3 material.
Step 3: Removed close out panel;.
Step 4: Match drilled hinge to the forward frame. Checked for .025 clearance.
34-4
Step 1: Dissaemble and deburr all door parts.
Step 2: MCS holes in hinge for 426-ad3 rivets.
Step 3: Dimple the holesin the close out panel and the underlying frames.
Step 4: didn't prime
Step 5: Riveted hinge to forward frame.
Step 6: Riveted frames to F 1059E skin and to each other.
Step 7: Riveted lock bracket to skin and upper frame.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
