Ivans RV 10
RV10
Tailcone Attach
7-16-2008
dimpling and riveting
32-5
Step 3: Dimpled holes in all skins commoin to the F1006ABC & D Bulkheads.
Step 4: Dimpled the aft most row of holes in the F 1077 mid bottom skin and the corresponding holes in the F1078 tailcone forward bottom skin.
Step 5: Dimpled the 10 holes in the triangular part of F1073 L tailcone side skin. Dimpled the matching holes in the mid fuse F1070 L.
Step 6: Dimpled the 3 holes in both sides of the F 1074 TC forward top skin common to the F 1046 longerons.
Step 7: Riveted the F 1078 TC FBS to the F 1029 Bell crank Ribs and F1047 stiffners.
Step 8: Riveted the 2 nutplates to F 1006B Bulkhead.
Step 9: Riveted the F 1006B bulkhead to the F1006A & C bulkheads
Step 10: Riveted the F1006B bulkhead to the F 1029 Bellcrank Ribs.
Step 11: Clecoed the tailcone back onto Mid Fuse then bolted the Longerons back together.
Step 12: Riveted the skins to the F1006A, B & C bulkheads
Step 13: Riveted the row of holes along aft edge of F 1077 Mid Bottom Skin.
Step 14: Finished riveting the aft portion of the F 1077 Mid bottom skin to the F 1019, 20 & 21 baggage ribs.
Step 15: Riveted the F 1070 Mid side skin to the Baggage door shim and the F 1023 L Baggage door angle.
Step 16: Riveted the F 1070 L & R Mid Side Skins to the F 1046 L & R Mid Fuse Longerons.
Step 17: Riveted the F 1019, 20 & 21 Baggage Ribs to the F1006B Bulkhead. Made a mistake on F 1021 R and had to rivet eith AD-62-BS 3/16 Blind Rivet.
Step 18: Installed the 2 snap bushings in F1006B bulkhead.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
