Ivans RV 10
RV10
Wing Tips
6-21-2008
OP-36
Wing Tip Lighting Left Side
OP36-2
Step 1: Trimmed the VA-194B Retainer Plate to match the Va-194C Cup. Deburred edges.
Step 2: Made 4 compression springs from the two 2.9' spring stock.
Step 3: Made 6 mount tubes from AT6-058x5/16 tube. See dimensions Figure 3.
Step 4: Used template on OP36-5 to mark hatched areas and position of screw holes for position and strobe light.
Step 5: Used position light base LN A650-PR-14 to match drill #27 the holes in Wing tip, Chordwise.
Step 6: Centered the W-1032 Landing Light Base then match drilled the 3 screw holes in the base to #27.
Step 7: Match drilled the nutplate rivet holes in both faces of the wing tip.
Step 8: CS the rivet holes
Step 9: Removed the hatched out areas of both faces of the win tip.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
