Ivans RV 10
RV10
Wing Tips
5-31-2008
Trim Wing Tips
24-2
Step 1: Trimmed both wing tips per figures 1,2 &3. Kept trimming until I was happy with fit.
Step 2: trimmed and squared the recess for the Wing Tip lens.
Step 3: Cut the Wing Tip Lens in half and marked them L & R.
Step 4: Slowly trimmed lens until achieving a good fit.
Step 5: drilled #40 the thru lens and Wing Tip per dimensions in figure 5. Then final drilled both pieces #28.
Step 6: drilled nutplate pattern as shown in figure 5. Cs the lens for #6 and the wingtip for AN426AD3 rivet. Riveted nutplates on.
Step 7: Installed Lens.
Both L & R Sides.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
