Ivans RV 10
RV10
Ailerons
5-18-2008
QB aileron completion L & R
Section 21 Complete
21-2. QB completed
21-3. Step 1. Clecoed the A-1006 Outboard Hinge bracket to the spar assembly.
Step 2. Final drilled the bracket through the doubler, spar and main rib spar.
Step 3. Removed and deburred parts.
Step 4. Clecoed then final drilled the A-1007 L & R Inboard hinge brackets on to aileron assembly. Removed and deburred parts.
21-4. QB Completed.
21-5 QB completed
21-6 QB completed
21-7 QB completed.
21-8 Step 1. Made (2) each of A-1012 and A- 1013 spacers
Step 2. Installed A-1007 L & R Inboard Hinge Brackets.
Step 3. Installed A-1006 Outboard Hinge Brackets
Finished with Section 21
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
