Made the connections to the elevator trim servo using a 5 pin molex connector set.(got a a GM aution) Secured the wires and coated the connector with silicone sealant to prevent moisture contamination.
Sealed connector into pvc tube to prevent bouncing and seal area to keep water from seeping in.
