Ivans RV 10
RV10
Sect 36
Brake lines
36-2.
Step 1 drilled 5/8 holes in Fwd fuse bottom skin.
Step 2 Istalled the 45 elbows and nuts onto landing gear mounts
Step 3. Installed elbows washers and nuts to F-1048 Ribs.
Step 4. Made the brake lines fronm .032 x 1/4 tubing.
Step 5. snap bushings mounted. Also Nuts and sleeves.
Step 6. Ckecked for proper orientation, then flared ends. Installed Lines.
36-3
Step1. Removed Vent Ducts.
Step 2. Installed elbows nuts and washers to Tri-gear Brake Bracket.
Step 3. Made brake lines from .032 x 1/4 Tubing.
Step 4. Put 4 cushion clamps on each line along with nuts and sleeves.
Step 5. Checked orientation. Flared ends.
Step 6. Attached lines to appropriate fittings.
36-4
Step 1 & 2. Riveted the Vent Flanged Ducts back onto the F-1048 L & R Ribs.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
