Ivans RV 10
RV10
Stall Warning System
Step 3. Deburred all Sub Ass. Parts.
Step 4. Assembled all Sub Assembly parts per Figure 1 Page 19-3.
Step 5. Installed Stall Warning Assembly to W-1008-R Splice Rib. Adjusted for minimum travel to activate and deactivate.
Step 6. Had to bend the vane slightly for perpendicular rest position.
Step 7. Made two 100" #18 wires (Wh-F1001) installed ES DV18-188M Female spade Connectors.
Step 8. Installed wires to COM and N.O Terminals of micro switch. Routed wires through the snap bushing in W-1008-R Rib aft tooling hole.
19.4
Step 1. Routed WH-F1001 Wires through snap bushings in main spar assembly.
Step 2. Taped wires to rib in main bay for now.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
